u joints in pre alpha sterndrive
jeepofino
I want to replace the u joints in my prealpha sterndrive while I have it off. how does the drive shaft come out or does it? I down loaded the manual but didnt' find anything about this in there. Thanks I have a 898 305
EddiePetty
Re: u joints in pre alpha sterndrive
...unless you have the 3-7/8" spanner wrench to remove the retainer nut behind the u-joints, you will be primed to break the retainer. Should you possibly remove the retainer, you will need to redo brearing preloads.
Best to get a qualified repair facility to do the u-joint job for you. :)
jeepofino
I can see buying the 3 7/8 spanner wrench but how hard is the rest. I have put ujoints in drive shafts in autos..big difference?
Bt Doctur
Actually depends on the gearset installed.The old style will slide off the yoke after you remove the nut(#28, this link http://mercstuff.com/fichea.htm. No pre-load pre se.The newer style gearset has the pre-load adjusted during assembly.
Alumarine
You might not have to remove the drive shaft.
On mine I used a grinder to give me clearance on part of the retaining nut so I could remove the ujoint.
Danny Mc
Ditto.. I did the same thing with a die grinder till the brg cap would pass, ground one of the slots a little wider and deeper. If you have changed many u-joints should not be a prob.
zbnutcase
None, as far as the actual u-joint itself is concerned....
Ayuh,.... I've run across Many drives with the big nut Clearanced....
jeepofino
A grinding it will be. I just couldn't see coming this far with resoration to send it to a repair shop for ujoints. I thought there must be something extra special about replacing them. Thanks guys!
ziggy
fwiw...
to ea. his own.
i got the spanner tool to remove the nut.
also, if ya don't have one. a ujoint press is a real winner. and the special merc tool for ujoint replacement is real nice too. made short, easy work of ujoints anyways...
jeepofino
Got it ground and drive shaft off....usually use a vice and c-clamp for putting them in.
