Re: Uh Oh... Prop Seal leaking gear lube on 89' 110 Johnrude!
Thanks 12footer! When I changed the gear lube AND screw gaskets, the old lube did have some water in it. I just wanted to see if the gaskets would do the trick, and I got my answer! This motor sat for 10 years before I got it running again, and I'm sure all of the seals need replacing anyway. I have a clymer manual but IMHO it is worthless. I'll buy an OMC manual that covers my motor. Will the whole gearcase need to be taken apart??? Thanks Again!!!
