Ultra HPF Gearcase lube color?
wespants
I changed my lower unit lube Sunday with what I am almost positive was Ultra HPF. It was yellow in color. I bought it about a year ago. I came up just a little short of the check hole, so today I went to buy some more lube to add. I took out the top plug, then the bottom and inserted the pump. I started pumping the new lube which I am positive was HPF (container looked the same) and it was a dark greenish color. I went ahead pumping until I ran some of the yellow lube out of the top. <br />My question is: what is the deal with the different colors, and should I go get more of the green stuff and pump the yellow completely out? Did the colors change last year, or, does it change over time?<br />Any help would be appreciated...
DHPMARINE
Re: Ultra HPF Gearcase lube color?
BRP changed the color,and they say it is fully compatable.Gonna miss that yellow color....<br /><br />DHP
marinemech
new formula for e-tec requirements its adirect replacement for hpf
Cricket Too
What is the new stuff for the e-tec called? Will it work for any lower unit?
wespants
Thanks a lot for the reply!! This eases my mind, and saves me a lot of time and trouble.
