Hi all,
I am unable to start the engine, have a good spark, suspected a bad fuel pump, replaced the fuel pump, same problem. After a few presses of the primer bulb, the bulb becomes hard to squeeze. Opened the line going to the top Carb,
squeezed the primer bulb, fuel comes out of the opened fuel line at a good rate. The engine runs when I squirt a small amount of fuel into the carb, stops after a few seconds. When I turn over the engine, very little or no fuel comes out of the open fuel line. I removed the fuel pump from the engine, put my finger on the hole that applies pressure to the fuel pump and I only feel pressure from the port when I slightly put my finger on the pressure port. The lines to the three carb's are ok. Any help would be highly appreciated.
August Beza
August Beza
