Re: under deck foam
Last year I had some weak spots in my boat's deck (1976 AMF SLICKCRAFT), so removed about 60 sq. ft. of decking to discover a lot of water saturated foam. Also discovered that most of this water had come from rain water running down along the outside trim rail to the bow tip, entering the front cabin, running under the vinyl cushions, into a covered storage box, under what you may call a subfloor bulkhead, then down the hull stringers, which saturated the foam and subsequently rotted the floor from underneath. Hull and stringers were fine. Dug out mushy foam and replaced with GREAT STUFF (Minimal Expanding Foam Sealant). I let it cure and expand overnight, then cut off excess with a hand saw and shaped with a hand sander. In the process of doing this work, I one day sprayed some of this stuff on a concrete block in my backyard. Never removed it and to this day, having been exposed to rain, hot sun and freezing temperatures, it's still intact, hard as a rock and stuck to the concrete block like I used epoxy. I wouldn't hesitate in using it again. Just don't shoot it into an inclosed space. The expansion force is too great.
