Re: under floor foam
Floatation foam's main purpose is just that, to help your boat to float if you take on lots of water.<br /><br />It is not meant to suck up moisture, although it will. Wet heavy foam is something that you would want to replace.<br /><br />It will add a structural component to your boat though and that's not a bad thing. The floors of many boats are not build atop the stringers because the stringers are too short and most floors lie on top of the foam.
