vprgtsr001
- Joined
- Jul 11, 2004
- 24
I bought a 94' Bayliner Capri 1500 last year. It came with a force 50hp motor. The motor sounds like its running perfectly, as in not firing on only one cylinder. Its a 16' fiberglass boat (runabout) for anyone thats not familiar with it. The maximum occupancy as stated on the plate is 4 people and 50hp motor. When i take the boat out with 4 people, avg of 150lb per person the boat can't get on plane. In fact it feels like its dragging. Anything less than 4 and she moves nice, althought at times its even a problem towing someone on a tube with only 2 on the boat and 1 on the tube. I would imagine if the boat is stamped for a max of 50hp it would at least move a bit faster/easier than it does. I was given the original sales slip when i bought the boat and it looks like it had the option for a 90hp motor. Some of my questions for people familiar with small boats like this are, does it sound like the motor is just underpowered for this boat, or should it be able to plane easily with 4 adults? Is it possible to put a bigger engine and have the plate changed? If im correct if you put an engine bigger than the plate says you can get in trouble with coastguard etc. Any suggestions/comments are appreciated!
