I have little experience with livewell systems and just purchased a 16' Sea Nymph FM161 that has one. The boat is a 1990 and I bought it from someone I know, so the information I am starting with should be accurate.
The boat has not seen water for 2 years, so after cleaning it up I took it to my local dryland marina and had it all checked over. They did the usual. Checked and reported on all systems, tuned up and changed the lower ends oil on both the main motor and kicker for me and replaced the trailer bearings (on my request). They reported that the engines ran fine, bilge worked, livewell worked, nav lights worked, etc.
So, this morning I take 'er down for her inaugural launch, only to find out as soon as the boat hits with water the automatic bilge pump kicks in. I jumped in and started to try and troubleshoot but I could not see anything unusual. By this time the ramp was starting to get lined up so I decided to pull it out again and continue to troubleshoot when parked.
As soon as I stopped my vehicle, I went around to the stern and noticed that, while the bilge was still pumping water out of the discharge hole on the side of the hull, water was gushing out of the livewell drain hole just as fast. And of course, as soon as I took the bilge drainplug out, water started pouring out of there as well.
So trying to figure this out, how was so much water coming out of my livewell discharge hole when I never filled it in the first place. Any help would be appreciated by this livewell newb.
