Underwater lighting
MWENGER1
Hi,
Can anyone tell me what the concerns , if any, in mounting 2 surface mount LED lights on my transom below the waterline. These lights are encased in a stainless steel mounting ring. They are made by Brighter Innovation. They are their Baylight model that produces 450 lumens. They are designed for this but was concerned about electrolysis. Any help would be appreciated. Thanks
Splat
Re: Underwater lighting
The stainless steel could create electrostatic galvanization if your mounting to a aluminum hull and using it in salt water. If in fresh water you'll be fine.
Bill
MWENGER1
Hi,
Splat, I should have givin more info. I will be mounting it to a fiberglass hull. The boat is moored in salt water from April till October. Any thoughts on this?
fdmsiv
You may want to find a different product. I have never had stainless in saltwater, but I have built a boat. Every told me not to use stainless and then cover with epoxy because without air, stainless with rust and deteriorate. I would try to find a silicon bronze or some other similar, or even plastic
