seanable
- Joined
- Sep 20, 2013
- 12
Hello Folks.
OK, so, I learned how to fiberglass, and glassed the deck on my '71 Thunderbird cuddy. Hand buffed 15 years worth of oxidation off of the hull, swapped out the lower outdrive, bought a new prop, buttoned up the wiring, new gauges where needed, new Walmart seats, new carpet, etc. etc. basically hemorrhaging money..take it out to lake Oroville last night...the 165 L-6 runs beautifully (after a carb. rebuild, new wires, oil change...) BUT...the outdrive makes a horrid grinding noise. I have run cars with wore out transmissions, and this noise is similar but louder and scarier
First question...What would be making that noise? It is obviously a bearing. It makes the noise in gear or not, and is more pronounced while in gear. i'd just as soon fix the 165 outdrive...but wouldn't mind taking this as an opportunity to upgrade...which brings me to my next question...
I acquired, sometime back, a 1987 Mercruiser 4.3 ltr. V-6. I sold the V-6, which was like new, leaving me with the outdrive, which sits in my yard. I would like to take this outdrive from the 1987 (which i believe to be an alpha one) and hang it where the '71 model 165 outdrive is. will it bolt up? are there any internals that are interchangeable? (hoping that I could fix the racket for no money, only my time and such. I also have the option of an older jet pump.....but i don't have it here and no information on it yet.
the old cuddy is epic fun. my wife and i had a blast. i am looking forward to taking the family out on it for some good memory making times. This forum has been key to me successfully making a lot of the repairs on this old cathedral hull. THANK YOU. and when i know what i am talking about enough to give sound advise, i will do that here.
