bugelingkayaker
- Joined
- Nov 13, 2019
- 49
not sure if this is the right forum for this post but i didn't see any other forum categories that seemed appropriate, so sorry if this is the wrong place to ask... I cant find any name plate on the tilt trim pump the only identifying info is the number: 45060A1
seems to be a merc. trying to google this leads to some search results that initially seem promising but then turn out to have no actual relevant info.
Anyways, this was a free boat, got the motor running so now im moving on to the tilt/trim. its got a three button switch, the buttom button works to lower it, the top one whines like the pump motor is spinning, but it doesn't actually lift the boat motor. from what i've read it seems likely that this was an issue of low fluid, so ive been filling it, or trying to at least. im not actually sure where i'm supposed to fill from because there seem to be so many possible spots. one of the pictures attached shows where i've been filling from. i'll take the screw out on either side, fill with tilt/trim fluid, close them, manually lift the motor up so it pushes the fluid through the line, lower, unscrew, fill more. so far i've put 4 8 ounce tubes of fluid into the thing and it seems to be almost full but it still wont lift. it works on down, it whines on up, but does not lift it.
anyone able to point me in the right direction for where i could find a manual for this thing? or even get me another name for the thing? its attached to a mercury 850 so im assuming this pump is by mercury too, but going through their online parts catalog searching the number above gets me nothing. any other thoughts on what the issue might be?
i found a wiring diagram on another thread in here and it shows the unconnected purple and blue wire going to some kind of timer switch i dont seem to have. not sure if that could be part of the problem. thanks for any info
