Universal Joint
laconia1997
Removing the u-joint assembly, do I need any special tools, Please help if you can, Thank you very much.
DP-SM 1.78 ​The dealer wants $120 an hour to do the Job i can't afford that.
tpenfield
You will need something to press the bearing cups out of the yoke. A large c-clamp can do the job, but a press is better.
jerryjerry05
You'll need:
Vice, and lots of hand tools, maybe a torch and a bearing press.
If you buy a press? Get a good one.
The yoke that comes out of the upper housing. Is it rusted along with the u-joints?
The seal that the yoke rides on will go once you start messing with it.
The rust/ corrosion will make it leak.
Volvo sells the complete u-joint assy.$586
The u-joint is $186(that hurts) you can find aftermarket.
The seal is not included..
laconia1997
Thank you Jerry, how hard is it to take the yoke out ? the dealer is telling me I need special tools to do this.
laconia1997
Do I need a rolling torque wrench​ for the carrier bearing after I take it off or just a regular torque wrench ? Thank you!
DP-SM 1.78
jerryjerry05
I tried to send you a PM but the site says I have too many messages or some such crap.
Over on marine engine . com the Volvo Forum
There is a guy called Rick he's real good on the Volvo drives.
He's the one to ask.
I'm not sure but I think you'll need to re-shim and do a rolling torque to reassemble the yoke.
laconia1997
No Title
Well, I was hoping to used the original yoke on my dp-sm 1.78 but this is what I found.
laconia1997
No Title
My gimbal bearing won't come off :mad-new:
tpenfield
Wow, what does the transom assembly look like where it came out of?
laconia1997
No Title
I spent two hours drilling the gimbal bearing out, No fun!:mad: on top of all that work I'm doing all this work on a floating platform:lol:
laconia1997
No Title
I take the pictures with my phone then I email them to my self, then I save them to a file, then I upload them to iboat. Thank you!
