Re: Universal Tilt Gauge?
I've got one, but I have it set up to my Quicksilver Paralift hydraulic lift (scissors type). The sender has a circular part about 1.5 inches in diameter and then a rotating arm about two inches long. The arm has a 90 degree bend at the last 1/2 inch or so, but you could bend it in other configurations if needed. Various other adjustments can be made in the throw of the arm as well as the position of the circular "core".<br /><br />You can contact the folks at Panther via their web site. I found them to be quite helpful when I was trying to rig up a gauge for this lift of mine - there is no factory sender for it, and this one was pretty easy to adapt and works well.
