Unknown propeller type
bblagonic
Hi,
Greetings from sunny Croatia!
My Johnson 60HP from 1984 (J60ELCRE) ser.no. 6101255 has a propeller with code JAA313.
The hub is damaged and the prop is in bad condiditon in general so I have to replace it.
Checking the adequate prop by the part list of subject motor type didn't make any results as it seems that lower unit is different from the original one. The subject lower unit has bigger shaft and housing when comparing to Johnson 60hp of nearest years.
The actual prop diameter is 12 3/4 ".
The housing of the prop is abt. 4".
Could someone help me in detecting the propeller which would fit?
It seems that the code JAA313 is a rare or old one and there should be some new code.
Thanks,
Bojan
