JasonJ
- Joined
- Aug 20, 2001
- 4,163
So last Saturday I used that 9.5 Rude to do some trolling, and it did okay, but seemed like it was not right. The last few days I have been dinking with it, cleaning points, adjusting this and that, and it always ran great in the can. Its when I finally put the shroud on while it was running in the can that the trouble started. It was acting like it was suffocating with the shroud on, the idle would drop, and it would not rev very well, but take the shroud off and it ran fine, so I figured exhaust leak. <br /><br />I found out that these low profile motors are a pain to get apart, but I got it down to the point where I could check the base gasket. It seemed fine, but I replaced it, and checked any other exhaust-oriented gasket while I was at it. Because I was concerned about air flow, I left that rubber flange thing off that goes around the leg and seals against the housing halves, thinking I would get more air to the carb. Got it back together, same deal. At this point, all I wanted was for the thing to run right, so I ended up cutting a hole in the shroud above the carb, affixing a tube to the carb that leads to the hoel in the shroud, and installing a clamshell vent to keed rain water out. It works, the motor runs fine now, but what on earth could have caused this. There was never any exhaust in the shroud when I would check. It would just want to die when I would put the shroud on, and run great when the shroud came off. Any insight would be appreciated...
