I tested out the boat Sunday, after adding instruments and a new rectifier to the engine. I was alarmed to see the voltage peg to max at some 16vdc. When I would stop, shutdown, and restart I would find it at 14 for a while, then soon it peged back to max voltage. Questions are:<br />1) what is the normal voltage output by these unregulated alternators?<br />2) Is this a good way to produce hydrogen in the battery and blow up the boat?<br />3) Is there a certain type of battery that should be used with this type of system?<br />Thanks. There has to be a reason that they went to regulated charging. Can you retrofit?
