Re: unstreight boat on roll trailer what is my problem
Sounds like there is a pretty good chance that you are backing the trailer in to far. I found with my old roller trailer that if i hooked the strap up and winched it on, it would load straight everytime. The rollers on the bottom should line the keel up as you pull it on. If you are in to far and the keel is not hitting any rollers as you load then the back will float all over untill you pull out and it sits down on the trailer wherever it happened to be floating at.
As far as how far to back it in, I have found that every ramp and trailer is different. But i usually back my bunk trailer in to just below the top of the wheel wells.
Hope that this made sense. Next, try experimenting some by starting to not back in as far. Also, you can watch other people at the ramp with similar sized boats and trailers and see what works for them.
