JimS123
- Joined
- Jul 27, 2007
- 8,311
I've gotten stuck engines running again in the past, but this one is a particular bugger. It's a 1941 Johnson 9.3 HP twin and the pistons are froze solid.
Its beeen soaking for a month now. One piston is all the way up and the other all the way down. I've pulled the exh manifold and can see the backside of the pistons and they don't look too bad. A slight ring of rust on one, but it wipesd right off. I pulled the lower unit and everything is oily and free moving.
The inside iof the carb and manifold are full pf bugs, dirt and leaves. I suspect its been outside for years. The top of the pistons and plugs are oily, so I don't think it was run without oil and has mechanical damage.
Any suggestions?
Any suggestions?
