Re: !unwinterizing a new 3.0 mercruiser
*Get an owners/shop manual asap....<br /><br />If you assume nothing has been done, meaning you don't really know what has and hasn't been done to the engine, assume you'll have to do the fall and spring maintenance:<br /><br />oil change,<br />oil filter,<br />fuel filter,<br />spark plugs,<br />drive oil replacement,<br />impeller replacement,<br />gimbal bearing inspection and lube,<br />ujoint inspection and lube,<br />inspect your belts, hoses,<br />shut off any open cooling lines/valves if open system,<br />prop removal/inspection/lube,<br />power trim/tilt level check,<br />power steering fluid check,<br />trailer bearing lube,<br />trailer tire pressure,<br />...might be more, but I can't remember at the moment.<br /><br />But get yourself a good manual or two, start reading, and familiarizing yourself with your engine.<br /><br />And welcome to iboats....
