Removed exhaust housing found all gaskets to be in good shape. But after looking real good I found a crack in the water jacket into the exhaust area. I used a Dremel tool to grind out the crack some and clean the area around the crack. and used JB weld to seal crack. I ran the motor for a good while in idle. No water on plug.
Larry
Larry
