Original problem.....I have a 4 hp evinrude outboard that will not start, because of firing. It came with the sailboat I bought in Feb. It started right up when I first got it and used it a cpl of times. I put the boat in for some bottom work and havent run the evinrude since march. Now it will not even fire. Fuel is getting to it but it want even turn over. Do not know the year serial# is Eooo2749, and model# is 46364. <br /><br />Update....Well I got new spark plugs and put them in, still would not fire so I took out the spark plugs loaded the holes with gas mix and it fired right up . But then it shut off no gas. Well took carburator off cleaned it and still doing the same thing out of luck I guess .here comes the ole outboard mechanic more bucks yuk!. Also what is it when oil runs out of the lower unit? (yes I had it in water when I was cranking it up)
