I posted last week about the atomizing coming out my four carbs. The mechanic indicated that the powerpack was defective and that the timing was way off. I could understand the bad powerpack but I don't know how the timing got way out of time. Today I went fishing for the first time since the repair and the motor went well at speeds up to 3000rpm and then I noticed the temp had gone into the overheat range. I went back to the dock at 1200rpm and the temp was okay. Can someone tell me why the timing should have moved as indicated by the mechanic and why it overheat at high speed and not at low speed. Also, can I use an automotive timing light or do I have to get a two cycle timing light or is that a silly question?
