Zamble
- Joined
- Mar 22, 2010
- 84
Well.... After all the work I did on the, I could not get them to function properly. So I ended up putting my boat back in the water and just left the engines in the down position. On my port I ended up with something happening and when I toggeled it up or down, I just heard the motor spinning freely. I pulled the shaft cap off and the tilt shaft was not broken. So I gave up. I just wanted to use my boat again.
I put it in at the end of July. I took it out three times. The first two it ran beautifully. The third time, I left my slip and apparently due to the ill kept waters of my old marina, the engine sucked something in the outdrive. Blocked the water flow and blew my Starboard engine. $9000.00 later, with a new engine, I finally put my boat in the water in two days, at a new, better marina. Right on the fish soon as I leave the docks. I just recently found out, the boats at my old marina are blocked in the slips. The hyacinth has the whole slough blocked in.
While the boat was being fixed I decided to have the marine shop fix both tilts. Come to find out, the aftermarket tilt motors, apparently are crap. My new set I installed were crap. The spinning in the port I heard was the shaft in the motor, was after the motor shaft sheered in two.
So my mechanic consulted a couple of "OMC Guys", and the collective opinions was that, do not buy aftermarket tilt motors. Stick with oem. Then he told me the price. I almost said screw the OMC guys. But for $259 a piece I said ok. And guess what...
They work great. No sticking, nothing bad to report. So after all the time I spent on them, and the money. I had given up. My lesson, oem first. Aftermarket only if I cannot find oem.
