Misterbulbous
- Joined
- Jul 12, 2018
- 47
Purchased my FourWinns H190 new in 2002. Running the 5.0GL-B carbureted engine and have never had an issue, never kept outside, never missed a scheduled maintenance, babied like my own child - roughly 300 hours on the engine. Idles fine, no "steady-state" issues, etc...
I cannot seem to overcome a nuisance issue with vapor lock. My situation is the same as described in so many other places...hour or two of cruising, sit idle to swim, start back up and idle for a minute or so and then has the occasional situation where the motor fumbles and dies when getting on plane. From there it's a matter of letting things cool down and/or cranking and cranking till it catches. Once it catches, we're off to the races again. It's not an "everytime" event, but usually at the most inconvenient time.
Before boating season begins for me this year, I've verified the anti-siphon valve is ok, I've sleeved the fuel line with heat shield, changed plugs (not that I suspect an electrical issue), confirmed my impeller condition and other cooling checks, cleaned the spark arrestor, and made sure the engine compartment is open and not stuffed with my wifes 10,000 towels, etc.
Question is...is anyone aware or implemented other countermeasures to make the system more robust? Fuel additives? booster fuel pump? etc?
(PS: I haven't verified the fuel pressure, but engine always runs fine other than this bog/quit problem when real hot out).
