soggy_feet
- Joined
- Oct 10, 2009
- 713
Last year wasn't so good for me.
In the water for about 4 hours before I hit a rock, then spent the rest of the summer trying to find parts or fabricate new ones after shearing the driveshaft in my R drive.
I was thinking I was going to get it back together and in the water this spring, but the more I think about the time and money I've put into that dinosaur of a drive, the more I think I should just junk the whole thing and start new(er).
The boat is from somewhere around 1970, a Stardust Cruiser 40.
It's got a GM 165hp Straight 6, and the upper drive is Alpha-ish, but the lower isn't, and I bought and tried every bearing carrier for the prop shaft I could find, and nothing fit it.
Now it's half cast aluminum, half billet. Working in a machine shop has some benefits.
Engine smokes a little on startup, but runs well, so I'm ok with keeping that, or if I can find the right package deal, I'll pull that too, but at this point I'm planning around that powerplant.
If I want to fit an Alpha 1 to the boat, I'm going to need a matching upper and lower (can't mix gen 1, gen 2, right?), as well as replace the bell housing/transom plate, and some sort of engine coupler, correct?
What are the chances that my 25ft long steering cables and forward/reverse cables will be useable with a newer setup?
Anything else I'm forgetting?
