Upgrading from Eagle to Lowrance unit
Tacklewasher
I've had an Eagle Fishmark 240 for a number of years and finally opened the wallet to buy a LMS-522 to get colour and GPS.
For some reason I figured I would have to swap tranducers, or get an adapter (part # 99-78 ta-x2u) to work with the old transducer but once I got the new unit, the connectors all look the same (except for the colour).
I had a portable kit for the Eagle, so on a whim I hooked the new unit up to it and everything seemed to work fine. It's been snowing here, so I ain't going out on the boat to try it, but are these two compatible? Both use a 200 kHz transducer.
I just don't want to fry anything.
I have asked the same question from Lowrance, but figured someone here might know.
whofan
Re: Upgrading from Eagle to Lowrance unit
Buy The new transducer for the 522c. You can sell the Eagle on Ebay with the old one and get some$$ back.
Tacklewasher
The issue I I had drilled a hole in the back of the boat, stuck the transducer through and sealed the old up with Marine Tek and sealed the whole transom. If I can get away with using the old transducer, I don;t have to put more holes in the boat.
The unit came with a new transducer.
Barnacle_Bill
They are different. You need to use the new xducer. Thats why they changed the color of the connectors so you don't get them mixed up.
