Re: Upgrading Speakers!!!
I laugh when people say that you will always get less performance without an amp. The only time you need an amp is if you drive the speakers hard enough that the present receiver's amplifier starts to distort. If you play the stereo and mid volume levels, you will never be able to tell the difference.
Hook up the new speakers and see how they sound. If you play your music very loud then maybe you might need one.
That's literally true, you always get less performance without an amp. Internal receiver amplifiers are not very powerful and prone to early distortion. You also must have an amplifier to run a subwoofer, which is a critical part of a quality audio system. If you just want some background tunes that's fine and dandy but there are plenty of people who really care about high-quality audio.
OP - you can run more than one speaker/subwoofer on a channel. They will be wired "in parallel," meaning the power the amplifier provides is divided evenly between the two speakers on that channel. When speakers are wired this way they also present lower resistance (measured in ohms, that's why each speaker has an ohm rating), so the amp can deliver more power. Two 4ohm speakers wired in parallel present a 2ohm resistance to the amp; as long as that channel is stable down to 2ohms you can safely run those speakers.
This is also why people run multiple subs on a single-channel monoblock amp; lower resistance = more power. Any decent sub amp will be stable down to at least 2ohms, so you can run two 4ohm subs off of it.
