Hi guys,
1987 Bayliner Capri 14' is the project... I am now to the re-upholstery part of this project... got the vinyl, creating the wood backing pieces as I go. I'm staining the plywood (after filling, sanding, and rounding the back edges) with an exterior deck water repellant stain (Thompson deck stain/seal).
I want to re-use as much of the old foam as I can, since foam is expensive as h*ll... I've been soaking it in a 1:3 mix of bleach and water to kill and remove all of the mildew and spores. Once it dries, it should be good to go.
Your thoughts/opinions? What about using a thin plastic membrane over the foam once the foam is glued to the wood backing but before the vinyl is stretched and stapled?
Thanks for your thoughts,
steve
steve
