upper and lower bearings
dcolpitts
1986 140 hp evinrude, looking for the best method to remove upper and lower crankshaft bearings
Dhadley
Re: upper and lower bearings
The upper bearing housing just slides off the crank. You have to press the bearing in and out of the housing. The lower comes off with any standard puller.
dcolpitts
Thanks Dhadley for the quick reply, does it help to heat the upper casing before trying to remove the upper beaaring?
Dhadley
No heat required. The housing and bearing will fall off the crank if youre not careful. The bearing will press out of the housing easily.<br /><br />Just make sure you have the replacement before hand.
rodbolt
hello<br /> to replace the upper bearing I just heat it with the tourch some and making sure the bearing is correctly oreinted it will drop in place. the bottom bearing I heat in a toaster oven to about 250*F and it will slide back on. make sure you orient the bearing properly.<br /> usually I dont replace the upper unless it shows signs of damage but always replace the lower.
