superflydudebike
- Joined
- Jul 16, 2007
- 130
I'm replacing water impeller on 1972 Evinrude 6 hp. In process, upper driveshaft pin literally fell apart. Can I make makeshift pin? Length? If not, where can I secure one? Also, it is necessary to replace the grommet on water pump housing too? This is my first impeller job, so any help will be much appreciated. Also should lower pin (which impeller sits on) fit tight on shaft? It easily fell out when removing impeller.
