swift1
- Joined
- Jul 15, 2009
- 26
Good day all. Been following this forum for quite some time and have picked up a ton of great advice. Now I'm looking for some more before I take my boat into the shop. I am mechanically inclined, but far from professional, so would like some opinions on my issues here.
I have a 1997 3.0L Merc with an Alpha 1 drive. Was out last weekend towing the kids when I heard a couple of clunks - could feel them through the hull as well. This went on and off as I headed back to the launch, then turned into a constant clattering noise. Should have tried to get a tow at this point, but I limped into shore and trailered home. Pulled the drive off and the bellows was full of gear oil. Gimbal bearing seemed fine, turned smooth, bellows seems ok as well - no water, just the oil. I inspected the u joint and there appeared to be some play as well as a grinding noise. That's when I pulled the top off the upper and saw the pile of metal shaving and the stripped gears.
So, would the oil leaking into the bellows cause the gears to fail like that, and would a bad seal cause the oil to get into the bellows? Aside from replacing the u joints, gears and all seals, is there anything else I should be looking at? And finally, do I need to tear down the lower unit as well to ensure no metal shavings got down there.
Sorry for the long post, just need to see what I'm getting into before I make the decision on myself or dealer for service! Thanks very much.
