Re: upper housing question
Originally posted by saltshaker:<br /> great forum i have just got into water sports and have a 87 searay bowrider motor is 3.0LTR 4CYL<br />mercruiser stern drive. have the motor out and not sure what position the flywheel should be in. After first remount test drive saw all six bolts shear off the flywheel is tension on bolts important and which position does the flywheel sit in please help..........
Hi saltshaker,+ Welcome to the forums here at iboats......<br /><br />While We'll get to Helping You with Your Issues,........You've got to Go About It alittle Differently............
<br /><br />Nobody is going to Find this, down here on dshelly's thread,......<br />This is called "Hyjacking" a thread........<br /><br />What You've got to do is,...... <br />Down at the Bottom of the pages here, at the lower left corner is a Buttom that says, "Post New Topic",........ Click on it........<br />That's where you can copy this post to,....That Way,.....<br />You'll have Your Own Topic line in the I/O forum......<br />And,... It appears you have a Very Unique Problem,..... It should draw Alot of comments......<br /><br />Get a Thread Started,+ I'll be over with whatever Info I can dig up in the mean time..........
