Gidday, I have a 1984 50hp Merc with loose upper mounts. I have removed the powerhead from drive shaft housing but am now having trouble freeing the rubber mounts from the bolts. All going well ! should the rubber mounts just slide off the bolts or are they threaded on ? I have also noted on other related topics people suggesting the removal of the lower leg for this opperation, why would I need to do this ?<br /><br />cheers in advancd.
