Re: Upper Pin on Gimbal won't come out
Removing the gimbal ring right? I assume you removed the nut on top and the clamping bolt for the steering arm. I think that upper swivel shaft has a threaded hole in it and you can screw a long bolt into and use a slide hammer. I used a bolt through a hole in a board, then used a hammer to drive the bolt down. I am not too familiar with one that old.
