Kubaat3lover
- Joined
- Jun 6, 2019
- 443
Is the one on the left metal ? It is a plastic washer. You can easily figure this out by assembling it. There is very little room between lever and bellhousing because the pin sits on the shaft in a fixed location. when it is all together if the washer is too thick it will bind up and the shaft will not swivel easily.Hello ive Found 2 washers in my box, which one has the right thickness according to OEM ? Can anyone measure it for me pls?
Ok Found the thickness is .030 so the left onehave a great day
