upper to lower outdrive connection ??
mike456
When I pulled apart my 1992 Alpha One outdrive to service the impleller I found that someone had put a some blue rubbeized caulking on part of it (S
mike456
tommays
Re: upper to lower outdrive connection ??
Thats your water pump dam it keeps the exaust from getting into the water pump <br /><br />There is a part in the upper also <br /><br />On older drives it was aluminum and then changed to rubber at some point<br /><br /> http://www.boatfix.com/merc/Servmanl/14/14b3.pdf <br /><br />Around page 78 will tell you all about it<br /><br /><br />Your look pretty rough could use some cleaning and outdrive paint<br /><br />tommays
mike456
Thanks Tommays. So if I read the manual right I can buy a rubber filler plug to replace my aluminum dam. Do you have an opinion on whether that is worth it? Is the part expensive?
tommays
it cant caust that much and should cut down on all the corrision going on in there<br /><br /><br />tommays
