urethane floor paint on fibreglass?
bandit86
Banned
I have several gallons of urethane floor paint, the can label says it's goo for marine use, I was going to paint under the carpets and under the cabin floor and under the seats. Is it a good idea or should I go and get some bilge paint?
dmarkvid2
Re: urethane floor paint on fibreglass?
Are any of the floor going to be exposed? Or will the floor paint be totally covered up by carpet? The reason I ask is, if you get that bare painted floor wet, you'll most likely slip, and fall on you a$$, or worse, out of the boat. It says its good for marine use meaning, good for the wood TRIM and HULL around your boat EXCLUDING the deck. I wouldn't use it, unless you're looking for a law suit. And I think that if you are going to totally cover the areas with carpet, it wouldnt last as long as if you used an expoxy.
dmarkvid2
Oh! I read the whole title now! You want to paint the fibreglass? I thought it was a wood deck. No you shouldn't use that, I think it would peel right off. Find a suitable fiberglass paint. What you have is for wood.
bandit86
Banned
cool, it would be under carpets and places where noone would ever see
BrettNC
I've used it. It is a one part urethane. It is the same thing that marine stores sell at triple the price. It adheres excellently and has a perfect gloss. Urethanes are typically sold as concrete floor paints also.
bandit86
Banned
thats what it is, floor paint, nice and shiney, but stinks for days
ondarvr
Why do you want to paint under the carpet?
bandit86
Banned
there is a lot of mold from waterdamage, I'm going to bleach and clean the whole cabin, i just want to seal out all the possible germs I may miss
garrett61
ya it peels and chips easily. I also tried it on an 8ft dinghy years ago it all chipped and peeled after 3 trips out. Its worth doing it right... It will save you a headache later in the season. Boats and the paint for boats isn't cheap for a reason.. <br />Good Luck
