ill start at the beggining i got a 9.8 merc 2nd hand in a bit of a state it wouldnt start seemed to have good compression on pull start i replaced the switch box and had her running so i decided to give her a new lease of life and repaint it. i removed the carb off the block and took the block out i have not took the block apart only removed the carb from it and replaced the spark plugs with the same ones i removed for new ones. repainted block and put it all back together. i cannot get it started and have tried numourous times i have changed the carb but still seem not to be getting any fuel to the plugs and for some reason the engine seems to have lost a load of compression on pull start it is easy to pull over where before it was tight to pull over i have put a compression tester on it and after 3 pulls it read 90psi on each cylinder i am at my witt ends with this so if anyone got any ideas i would be gratefull if you could reply as i really want to get moving on the river
