Re: USCG License
I got mine in 1993. 125 gross ton limit with a towing endorsement. Get a copy of Chapmans and read it from cover to cover, over and over until you have a working knowledge of all aspects of it. Make flash cards for the rules of the road, you need a 90% to pass that part. Get your underway resume in order and make sure you have enough hours to get the license you want. Be prepared to back up the hours you log on your resume. Have someone who's taken the exam test your knowledge before you take the exam. Study your weak points alot. You must pass each section of the exam AND the exam as a whole. So, you can get a 90% on the whole exam, but get a 74% on weather and still fail. So study your weak points until your comfortable with the material and don't give up on a subject and hope there won't be many questions on it. Each section, except for the rules of the road, has nearly an equal number of questions (about 5 or so), and each section requires a different grade to pass. So it only takes a little "oops" to fail the whole thing.
It's a hard test, especially taking it your first time. I would say an experienced mariner should study regularly for at least a month before taking the test.
Another tip: You can take the Rules of the Road test separately and I would suggest doing that. Study all out for that, take and pass it, then take the rest of the exam. If you want the towing endorsement, tell them ahead of time. It's also a separate test, 10 questions and VERY easy if you know anything about towing.
Good luck and let me know if I can help further.
DR.
