Use Filler Around New Transom?
mspring
I cut the 2 pieces of 3/4 plywood for my new transom but I dont think it is going to be as tight a fit as I hoped. Can I tear some shreads of chopped cloth, mix it with resin for strength, and pack it in around the transom?
I have seen guys use the fiberglass tape around the edges but should I also cover the inside with mat or roven? It seems like if your using a sheet of cloth to cover the inside you wouldnt need to use the tape.:confused:
tashasdaddy
Re: Use Filler Around New Transom?
fill the void. i usually cut my fabric, over sized and wrap the seams, to the gunnels, and hull bottom.
mspring
No need for the biaxel tape if done that way right?
tashasdaddy
i've never has a problem.
