Use one 1.5" ply or 2 .75" ply for transom
Datimm
I am very new to this and have recieved so much info from this site, so thank you for that. I am replacing the transom on a 1986 rinker v180 and I am about ready to start the rebuild process. I can not find any info in if it would be a good idea to use 1 piece of 1.5" plywood or not. Eveything says to get 2 pieces of .75" and laminate them together, so I can assume there is a reason for that. Can anyone tell me that reason? Thank you.
JASinIL2006
I think the biggest reason is that 1.5" thick exterior plywood is not all that common and probably costs an arm and a leg, if you can even find it (or special order it). You can find three-quarter exterior plywood all over the place and it's usually not too expensive. I don't think I've ever seen 1.5" plywood.
^^^ Agree, use 2 layers of 3/4
After bonding the 2 layers together, and bonding to the hull, then layers of glas over the top, will give you the required 2 inch +/- a tad
Redtruck12
No such thing as 1 1/2 inch exterior grade plywood
3/4 doubled up is the way to go.
Datimm
Ah, that explains why then. Thanks for the quick reply.
Woodonglass
What power plant and outdrive do you have. Different Power Trains required different final specs for your transom build. Usually 2- 2 1/4" You fiberglass laminations will only add about 1/8" in thickness. I'd consider using 2 3/4 layers with a 1/4" layer sandwiched in the middle. Reason...Plywood thickness today is 23/32 and 7/32. so to get where you need to be this is the way to go.
