Used boat: Glastron, SeaRay or Chaparral
aJohn79
I did not know where to post this, so I will try here instead.
I am looking to buy a used boat for 5,000ish (non-OMC). I will be using the boat on lakes for fun and some skiing. In my area here are some of the options:
1998 18' Chaparral open bow
4.3 L mercruiser
18' 1990 SEA RAY 180BR
4.3 L mercruiser
1993 GLASTRON SSV 175
130HP MERC IO
Based on your experience, what are the pros/cons of each brand? any recommendations?
Thanks.
SpinnerBait_Nut
Re: Used boat: Glastron, SeaRay or Chaparral
Boat topics and questions, non engine forum.
ovrrdrive
Normally I'd like the Searay but that one is getting a little old. If the Chaparel has low hours I'd probably go for it.
tashasdaddy
out of the choices, not knowing conditions, 1998 18' Chaparral open bow
4.3 L mercruiser. the glastron is underpowered.
aJohn79
Are Chaparrals good boats? Is the Merc 4.3L a reliable engine?
cmcpherson
Banned
Get the boats checked by a professional, they are all quality and the wear and tear needs to be evaluated by someone who knows. The Glasstron is not underpowered, I had a 3.0 18 foot Sea Ray for years that I skied behind many times with 7 people on board. FYI, I am 6'2" and weigh about 255, if it can pull me out of the water with a full load, you should be fine. The 4.3 is a great engine, but the 3.0 is an absolute tank and will run forever if cared for properly. This is a topic that has been discussed over and over around here. If you want to go 50 MPH you are not going to get there in the 3.0, but with gas prices right now...
