Used boats.
prodow
Help! I'm looking for help in finding what would be a fair price for a Sea Nymph, 17'alluminum boat, 1984 with 40 horse Evinrude motor, Very good shape. I tried search on the web and found this web. I'd appreciate help in leading me in the right direction.<br />Thank you.
Hooty
Re: Used boats.
Wish I could help. You could try this web sites "Boating Classifieds" and try to find something comparable.<br />g'luck & c/6<br />hooty
D
DJ
Guest
Re: Used boats.
Prodow,<br /><br />I am currently restoring a 1983 16' Sea Nymph AL Bass Boat with a 90 Rude. The hull is in great shape and the engine appears to be OK. It's sitting on a nice trailer (Shore Land'r).<br /><br />I gave $1,000.00 for it, simply because of it's potential. Unless this unit is absolutely pristine I wouldn't think it would be worth anything over $1,500.00. That's with a proven good engine. See it run!<br /><br />By the way, Sea Nymph has merged with Lowe.<br /><br />I've been around alot of Sea Nymphs. They were well built boats. Take a good look at the bottom. If it has alot of dents-pass on it. The dents tend to loosen the rivets. If the bottom is straight, you'll be OK.<br /><br />Also, check the transom. They were wood encapsulated by AL. Knock on it with the back of your hand. If it does not give a sharp knocking sound-it's rotten. Sort of like the sound made by knocking on a solid wood door.
