used lower unit
RiL
I am thinking about buying a used lower unit for my 1970 johnson 60hsp elect shift motor. <br />Is there anything I need to check or have checked before spending the $$$ on a used lower unit? They say it has been presure checked.<br />Thanks, <br />Rick
RPJS
Re: used lower unit
Hi Rick<br />I would check the following:-<br /><br />1: Test the gear change solenoids, meter each wire to earth you should get aprox 8 ohms on each wire. A very high resistance or open circuit shows the solenoid is U.S<br /><br />2: Turn the drive shaft clockwise, the unit should be in forward gear, listen for any odd noises.<br /><br />3: If all seems well and you purchase the unit change the oil and impeller just to be safe.<br /><br />Best of luck<br /><br />Richard
RiL
Re: used lower unit
Ok RPJS,<br />Im a first time boat owner. Slow down and speak land lover :confused: lol<br />#1 where is the gear change solenoids and what do you mean by US?<br />#2 I have not been able to find on locally so I was thinking about ordering from one of two places that say they have it is stock, Nicks marine or Outboard exchange. Have you know anything about these? <br />#3 I am going to do this <br />If a person orders a remanufactured unit should it come with the seals in place and with the impeller?<br />Thanks,<br />Rick
RPJS
Re: used lower unit
Sorry Rick I'll try again.<br /><br />1: The gear change solenoids are mounted just in front of where the drive shaft enters the water pump, there will be 2 wires from the solenoid housing these are the ones you must check, using a standard electrical meter conect on lead of the meter to 1 wire at a time and the other lead to the casing of the lower unit, you should get a reading of 8 ohms if the reading is much higher than 8 ohms or open circuit the solenoids are U.S (Up the Swanee).<br /><br />2: I have never had dealings with either of the 2 names you mention, however if as you say you are getting a remanufactured unit you would expect it to have some sort of guarantee and the supplier will be able to tell you what work has been done to the unit, at a minimum I would expect the oil seals to have been replaced, get the dealer to put in writting the work he has done just in case(if they are a representable outfit they will have no problems doing this).<br /><br />Happy Boating<br /><br />Richard
tmcalavy
Re: used lower unit
Hey RiL<br />I'm up on the caprock, too. If it were mine, I'd consider looking for a whole used outboard at one of these two sites:<br /><br /> http://listings.ebaymotors.com/aw/plistings/list/category26443/index.html <br /><br />in layman's terms that's ebay.com, then ebay motors, then Parts and Accessorie, then Boat & Motors<br /><br /> http://www.aomci.org/webads.htm <br /><br />That way you get a whole motor for replacement parts. With a little patience, you can get a whole motor for about what you'd spend on a rebuilt lower alone.
icwebpeople
Re: used lower unit
be cautios of nicks marine i ordered a complete dist cap and it came with car plug wires on it.<br /><br />Here are some email addresses and contacts I have found and I have bought from a lot of them. If you don’t have outlook express you may have to type the e mail address in your e mail instead of just clicking on it. I would start a the top of the list and go down that’s the order I have had the most luck with.<br />Good luck <br />discount marine weedsport n.y. ask for wayne 315-834-6843<br />www.GLM-marine.com 626-357-0077<br />nicholls marine ltd 905-871-1965<br />nicks marine 859-854-3888 let it ring a while<br />www.americanoutboard.com <br />chesapeak marine 410-286-2520<br /> http://www.bentboat.com/parts_toc_fr.html <br /> fairwinds@toad.net<br /><br /> mtech@mastertechmarine.com<br /> FranzMarine<br />linda@nu-z.net<br /> discountparts@americanoutboard.comservice@boatmotorrecyclers.com<br /><br />willyo@bellatlantic.net<br /> info@outboardexchange.com<br /><br /> info@ccomarine.com<br /><br /> sales@marineparts.com<br /><br /> DSTIBER<br />obparts2@yahoo.com<br /> Tsmyth@cfl.rr.com<br /><br />partsdesk@tenkillermarine.com<br />partsform@newagemarineparts.com<br />manualform@newagemarineparts.com<br />charlie@charliesusedparts.com<br />ironman@csweb.net<br />outboard@searnet.com<br /><br /> http://www.nicksmarineoutdoors.com/NicksMarine_Storefront/asp_StoreFront/QuickOrder_Launch.asp <br /> http://www.iboats.com/ <br /> http://www.geocities.com/thechryslercrew/ <br />you can post an add here http://www.hurrikain.com/disc1_index.htm <br />post an add here http://www.iboats.com/cgi-bin/ubb/ultimatebb.cgi <br /> http://www.marineengine.com/outboard_motors/parts/ <br /> http://www.boatowners.com/drives_vdrives.htm <br /> http://www.fairwindsmarina.com/chryslerpage.htm <br /> http://aolsearch.aol.com/dirsearch.adp?knf=1&query=chrysler outboad parts <br /> http://aolsearch.aol.com/dirsearch.adp?knf=1&query=chrysler boat parts
