Re: used motor
Under the rear of the cowl off to one side where the water pisses out, there should be a rubber grommet. This is where to stick the wire.
The water will all drain out the exhaust, so this should not be an issue.
Before you buy the impeller, take it apart first. There are at least three different kits. They are all the same parts, just more parts in different kits. e.g. There is a SS cup that the impeller rides in, if it's scored, you'll need to replace that too.
Personally, if it were mine, I'd spring for the full kit ($50) which has everything - gaskets, seals, housing, etc. This way, you know what you have and may save a second trip to the store.
