ottawamerc
- Joined
- Sep 16, 2004
- 128
I have a 1981 228 hp apha 1 R model lower unit. My original unit tossed a forward gear so costs dictated that I buy a used similar lower end. I rebuilt the lower end with the best parts from both units. Now before I match the lower unit to the upper gear case I can shift forward-neutral-reverse with a positive lock in both. Once matched to upper unit and attached to the boat it would not shift to reverse. I check all shift cables and adjustments and they seem ok. I finnally added a little shim material to the shaft in the upper gearcase that mates to the lower unit. I now have a marginal reverse but I can rotate the prop against the clutch? I'm starting to think that I might have to shim the reverse gear to get a proper lock, although there was no shims present when I disassembled the unit.<br /><br />Any suggestion would help!!!
