Used parts
Fella
Does anyone know where to find used parts. I possibly need a cdi box which are fairly expensive and I am just getting the engine running to sell it. It is a good motor but I lost spark. It may just be the coil I haven't pinned it yet but never the less I will need some parts. It is a 1975 650 65hp merc.
Thanks
WillyBWright
Re: Used parts
I wouldn't consider a used part that you're looking for to be reliable, depending on the source. Check on eBay, try tcoutboards.com. I also wouldn't assume that the part that you're looking for is the part you need. But even if it is, you might spend more time and money trying to cheap-out than if you just do it right the first time. Or bail on the motor altogether and eBay the good parts. Don't get caught-up throwing good money at a 32 year old relic. You can get good money for healthy powerheads, gearcases, starters, etc. A lot of times you can get a lot more for it that way. As is, your whole motor is worth maybe a couple hundred bucks. The gearcase alone might be worth a couple hundred bucks.
Fella
Re: Used parts
What would you assume is the part I need? The motor ran great last time out but now has no spark. I was told it may be the stator but this motor has a distributor and I think, and I am not a mechanic but on this unit the stator is used only for charging the battery. Please correct me if I'm wrong.
