Johnson 70 seized a piston as I posted about before. We found a used Evinrude 70 E70ELCIM. The Johnson is J70ELCD. Evinrude is a 1981 and the Johnson is a 1986 vro. Compression is great in the Evinrude, so we are wanting to put the Evinrude block in the Johnson frame. Can we put all the Johnson electronics and carbs on the older Evinrude powerhead? We are not going to hook up the Vro again, but wanted to use the newer motor parts as much as possible. Would have been simple to just use the complete older Evinrude, but that motor has been in saltwater and in the elements, so the Johnson appearance is much better. Thanks
