Using a Spark Tester
DC20
Just got the individual gap tester. I have a 6 cylinder motor. I understand you remove all of the plugs and ground the remaining 5.
What is the best way the ground the other plug wires?
mrcj001
Re: Using a Spark Tester
place them on top of a bolt head that are around the head. If not , just make sure they stay away from the spark plugswhen testing.
F_R
If you were doing this all the time, you would get a tester that does all 6 at once. Othrwise, the best way is make up some wires with alligator clips on both ends. Clip one end in the boot and the other end to a ground.
SeaKaye12
If you have electronic ignition it's pretty important to be sure they are grounded. You might make up a simple device that has 5 quarter inch bolts sticking out of a piece of wood....all wired together with an alligator clip on the end of a wire.
Push the spark plug boots onto each of the five bolts...and clip the alligator clip onto an engine ground.
DC20
Yes, electronic ignition. I am making something right now to ground the other 5.
Does it matter if the plugs are in or out?
Thanks guys.
DC20
Well I found intermittent spark on the port side, top and bottom, the middle looked ok.
I think this might account for the occasional miss I have.
I have another thread for that, thanks for the help.
SeaKaye12
Thanks guys.
You would typically have all the plugs out if only to enable faster spin-over and less strain on the starter and battery.
