Re: Using aluminum Intake
Hey Bondo and I are almost neighbours.. I'm always nice to my neighbours,even if I don't like'em, and don't worry Lube you also give good advise to, anyway I got done installing the Edelbrock Performer intake and carb, turned the key and fired right away.....I'm totally pleased with the performance, throttle response is instant and low end torque is is excellent, I would just like to give a few tips for anyone that may not already know. If you are thinking of upgraded your Merc small block to a Edelbrock performer Carb, you can get the fuel line from pump to carb from Merc, you just need to order for a Weber carb'd Merc 5.7 litre Alpha, fits perfect and looks real clean, you may also have to get a elbow fitting also for fuel pump, you may also have to change your throttle cable bracket,I did because I went from 2bbl to 4bbl, if so then you will also need to get the Throttle cable stud and lock nuts also, the only throttle cable bracket available from merc now is stamped steel and appears to be somewhat universal fit, I also ordered the carb studs and lock nuts also From Merc with this said the job was smooth a quick, took me about 3 hours and no hassle's trying to make parts fit, I thank all that replied to my post. Oh ya gas was about $4.50cdn a gallon today for 92 octane ,good time for this upgrade
